80' Trailfire 340/440 Chaincase
JDFanatic19
So we bought two JD's last year, didn't use them much last year. We're taking the chaincase apart for the upcoming winter and figured out its scratching the casing. And the tensioner is a made-up one. So i cant find a diagram of the whole chaincase so i can see what parts are missing. Does anyone have a diagram of a 1979-1980 JD Trailfire 340-440 Chaincase?
Dillon Devine
Chatham ON
2 1979 John Deere Trailfire 340's. Also have seized 340 and 440 (later to be rebuilt)
1990 ski-doo safari (Dad's Sled)
Chatham ON
Re: 80' Trailfire 340/440 Chaincase
http://jdpc.deere.com/jdpc/servlet/com. ... ,+KeylinesJDFanatic19 wrote:So we bought two JD's last year, didn't use them much last year. We're taking the chaincase apart for the upcoming winter and figured out its scratching the casing. And the tensioner is a made-up one. So i cant find a diagram of the whole chaincase so i can see what parts are missing. Does anyone have a diagram of a 1979-1980 JD Trailfire 340-440 Chaincase?
JDFanatic19
That link you sent me doesnt work
Dillon Devine
Chatham ON
Chatham ON
That diagram is a little confusing because I don't believe you will have items 9,10,11,12,13. That's the roller tensioner that wasn't normally used on the trailfire.
JDFanatic19
Thanx a bunch. But yea i dont have 9, 10, 11, 12, and 13. It doesnt have a whole for 5 and 6. It has a pin and a slot for a tensioner. The guy i bought this JD off of one made his own up. So i don't know what it looks like. What is number 7?Matt wrote:That diagram is a little confusing because I don't believe you will have items 9,10,11,12,13. That's the roller tensioner that wasn't normally used on the trailfire.
Dillon Devine
Chatham ON
Chatham ON
JDFanatic19
7 looks like the tensioner i have. The chain doesn't seem to be tight enough. Its still pretty looseMatt wrote:7 should be your tensioner.
Dillon Devine
Chatham ON
Chatham ON
- johnnycyclone
- Real Name: Terre
There are different combinations of gears, and chains you can run. I would start by counting the number of teeth on the top and bottom sprocket, and also count the number of links in the chain. You can then compare what you have to what Deere recommends in the service manual. If you have too much slack with the tensioner installed then something is not right.
Terre
Terre
JDFanatic19
The only problem is i dont have a deere manualjohnnycyclone wrote:There are different combinations of gears, and chains you can run. I would start by counting the number of teeth on the top and bottom sprocket, and also count the number of links in the chain. You can then compare what you have to what Deere recommends in the service manual. If you have too much slack with the tensioner installed then something is not right.
Terre
Dillon Devine
Chatham ON
Chatham ON
- johnnycyclone
- Real Name: Terre
- johnnycyclone
- Real Name: Terre
If you need any help, just keep asking questions.
Terre
Terre
JDFanatic19
Ok, thanx a bunchjohnnycyclone wrote:If you need any help, just keep asking questions.
Terre
Dillon Devine
Chatham ON
Chatham ON
