spitfire snowcross build
rogganater
Post by rogganater »
building a late 70s 340 spitfire for my snow cross sled for the light weight and one have any information on aftermarket gears or where to get them ???
Mathew Robert
Re: spitfire snowcross build
Post by Mathew Robert »
I think spit fires are direct drive the only gear is in the track
1983 sprintfire (original everything but paint)
1975 jd 400 (will be restored)
SpitfireKing
Post by SpitfireKing »
Ya, tough to get gears into a sled with no chaincase :P, adding a chaincase seems like blasfimy (sp) to me.....but I also dont know how much power the stock drivers and secondary could take if a larger motor was added. They had about 2"'s of travel so any jumping would require a lot of stiffening in the front and some sort of new skid design in the back.
Be interested to see your ideas..good luck!
liquitisplit80
Real Name: Roy
Post by liquitisplit80 »
They did come with either 7 lug or 8 lug drivers. That would be the only 'gear' change you could make.
'78 Spitfire
82 Trailfire 340
'80 Trailfire 440
'80 sportfire
'81 liquifire
Still ridin' the New Breed!
