spitfire snowcross build
rogganater
building a late 70s 340 spitfire for my snow cross sled for the light weight and one have any information on aftermarket gears or where to get them ???
Mathew Robert
Re: spitfire snowcross build
I think spit fires are direct drive the only gear is in the track
1983 sprintfire (original everything but paint)
1975 jd 400 (will be restored)
- SpitfireKing
Ya, tough to get gears into a sled with no chaincase
, adding a chaincase seems like blasfimy (sp) to me.....but I also dont know how much power the stock drivers and secondary could take if a larger motor was added. They had about 2"'s of travel so any jumping would require a lot of stiffening in the front and some sort of new skid design in the back.
Be interested to see your ideas..good luck!
- liquitisplit80
- Real Name: Roy
They did come with either 7 lug or 8 lug drivers. That would be the only 'gear' change you could make.
'78 Spitfire
82 Trailfire 340
'80 Trailfire 440
'80 sportfire
'81 liquifire
Still ridin' the New Breed!
82 Trailfire 340
'80 Trailfire 440
'80 sportfire
'81 liquifire
