1976 340 Cyclone Restoration
Re: 1976 340 Cyclone Restoration
I have always went bolt heads on the inside of the tunnel.
Even though the parts manual shows them the way you have them they built them the opposite way.
eppjd
Post by eppjd »
Good to know. Thank you for the advice.
Adam Epp
Winnipeg, MB, Canada
74 400 (2 - sold)
chriszildjian17
Real Name: Chris Farrell
Post by chriszildjian17 »
Hows the cyclone coming, excited to see this come along.
79 spitfire. 78 cyclone 440
76 liqufire 340. 80 liquifire
76 liquifire 440 x 2
eppjd
Post by eppjd »
Progress has been slow the last couple months, what with work obligations/waiting for parts/and the slowing effects of a few dozen cases of beer... Lol but it is coming together slowly, will post more pics as progress is made
Adam Epp
74 400 (2 - sold)
JD600
Post by JD600 »
Hey Adam,
What did you end up using for bushings in the suspension tubes? I am going to assume that with a little bit of lathe time, you were able to fashion new ones? I'm getting close to needing some for my Black Triplets, and i figured you probably already had this problem solved.
DE
P.S., I assume Scott delivered your boosters a few weeks ago?
S_Kyle
Real Name: Scott Kyle
Post by S_Kyle »
JD600 wrote:Hey Adam,
DE
Dustin, I believe Adam was able to locate NOS suspension bushings for the project. If I remember correctly their was one plastic piece we had to reuse and we were able to find a good one out of the various suspensions lying around.
JD600
Post by JD600 »
Thanks Scott. I guess i will continue to brainstorm this one then.
DE
ihengineer76
Real Name: Tom Rehberg
Post by ihengineer76 »
I've had luck before finding bushings from McMaster Carr, MSC, and Grainger. You can find just about any dimension and material you want. I rebuilt the suspension on my 76 Liquifire with Oilite bronze bushings from one of those sources.
JD600
Post by JD600 »
I checked fastenal, and McMaster, but i'll keep loking i suppose.
Thanks for the tip,
DE
eppjd
Post by eppjd »
Hey Dustin, yeah like Scott said I had some NOS plastic. I suppose new ones could be reproduced easy enough, would just need the right material.
I assume Scott has my coils and your idlers, lol haven't talked to him much about sleds lately.
Adam Epp
74 400 (2 - sold)
JD600
Post by JD600 »
Adam,
I didn't send idlers with Scott. I have them split and plan on polishing them before i send them to you as they are much easier to polish in pieces. I'll give you a shout when i get them ready.
DE
