Square back skis, look like early 70's Cat skis.
Tail edge looks worn trough also.
1980 JD Liquifire by SnowKat79
Re: 1980 JD Liquifire by SnowKat79
Kinda figured they werent right..... Thanks Todd.
having some trouble getting the top coolant pipe off. bolts are not cooperating, er at least one isnt! it turns a little, and then feels like it could twist off
going sandblast the exhaust, and repaint.
Is there anything on the oil injection pump that I need to go through or check before putting this engine back in service?
There is a testing procedure for the oil pump in the service manual. It's available on vintagesnow.com if you don't have one.
Thanks Matt!
Got the exhaust repainted with CAT Hi-Temp muffler paint...pics to come soon
Also, got the lower collant pipe blasted clean, and sprayed in a clear laquer. I will get pics of that too.
- Danzig
- Real Name: Paul File
if you painted clear on aluminum that gets hot you may hate it, we did this on a motorcycle engine and the stuff turned brown and flaked off in little pieces, looked like it had a sun burn that was peeling...........
I will keep that in mind. I guess, worst case scenario....I have to re blast those parts.Danzig wrote:if you painted clear on aluminum that gets hot you may hate it, we did this on a motorcycle engine and the stuff turned brown and flaked off in little pieces, looked like it had a sun burn that was peeling...........
