suspension shocks
largecar04
- Real Name: scott ohm
suspension shocks
Ok, so I'm back to working on my sleds and I'm still frustrated with one thing, the suspension shocks that are shot! After all of this time has anyone found a bolt on replacement gas shock for the trailfire and sportfire? I know a few of you have made some shocks work that didn't quite fit right but I really don't have time to do much more than bolt them on.
02 arctic cat zr 800 efi
02 arctic cat zr 800 cross country efi
- Liquifried
Re: suspension shocks
I don't have the part #, but you can take the measurements off your original shock and find one at Dennis Kirk. I bought a few and I think they were Kimpex replacements for a Cat or Polaris, but the dimensions were the same. Seem to work fine and they were like $25 each.
Not cheap, but you can also find NOS from
http://www.imageenterprises.com/john-de ... r-sale.cfm
74 Evinrude Skimmer 400
82 Trailfire LX
82 Sportfire (Electric Start)
83 Sportfire (Original Owner)
83 Liquifire
84 Sportfire
97 Indy 500 Liquid
1996 Polaris XLT Touring
82 Trailfire LX
83 Liquifire
84 Sportfire
97 Indy 500 Liquid
largecar04
I spent a little time in NAPA today and came up with a shock for 1939-1950 Chrysler/dodge and 1950-51 vw bugs that should work for $30. I ordered one and will be test fitting it Wednesday. I'll let you know!
largecar04
So I got the shock mounted today and it seems to work fine. I did have to trim the rubber bushings a bit but nothing major. I got a foot of bushing stock 5/8 x 3/8 and cut it into 1 1/4"lengths then drilled them to 7/16 and installed. The shock is about 3/4" longer when extended but I don't think it will be a problem. I've got some pics if I can figure out how to post them.
- Liquifried
What is the NAPA part #
82 Trailfire LX
83 Liquifire
84 Sportfire
97 Indy 500 Liquid
82 Trailfire LX
83 Liquifire
84 Sportfire
97 Indy 500 Liquid
largecar04
NAPA & O'Riellys part numbers are the same. It was $30 at NAPA & $27 at O'rielleys. Its a sensa-trac 5752
- acesillini06
- Real Name: Matt Cappel
These gas shocks from NAPA fit great. part #5752. $30
trailfire runner
What sled did you put this on?
Clay
Clay
Clay Gerfen
My Sleds
1 1978 Spitfire
1 1979 Spitfire
My Sleds
1 1978 Spitfire
1 1979 Spitfire
chriszildjian17
- Real Name: Chris Farrell
By the mounting if the shock, looks like a sprotfire,trailfire
79 spitfire. 78 cyclone 440
76 liqufire 340. 80 liquifire
76 liquifire 440 x 2
- acesillini06
mounted on a 1983 Sportfire. and transfered bushings from old to new shock
Matt, was that a "press out" / "press in" bushing replacement?
- jdrob
- Real Name: Rob
Matt you may have just become alot of guys new friend.mounted on a 1983 Sportfire. and transfered bushings from old to new shock
Jdrob
- acesillini06
just like largecar said... you have to drill out the rubber on the new shock a little and burn out the rubber on old shock to get bushing out and install and RIDE!largecar04 wrote:So I got the shock mounted today and it seems to work fine. I did have to trim the rubber bushings a bit but nothing major. I got a foot of bushing stock 5/8 x 3/8 and cut it into 1 1/4"lengths then drilled them to 7/16 and installed. The shock is about 3/4" longer when extended but I don't think it will be a problem. I've got some pics if I can figure out how to post them.
