Has anyone found a good product to use that restores the black hard cowling plastic ?.
Just looking for a quick spray product, not looking to repaint.
WD-40 is not the answer I'm looking for.
Hope someone has found something good.
Black hard plastic restoration
- GreenGenes
- Real Name: Terry
1973 JDX-8
1974 JD300
1981 Liquifire
1981 Jag F/A 340
1974 JD300
1981 Liquifire
1981 Jag F/A 340
Re: Black hard plastic restoration
You'll probably get several replys all of which will be good. Personally I use Bondo's "RestoreBlack" from Walmart.
DA...you ever had issues with the restore black flaking off a year or two later?
I used it on a tank. Scrubbed with soapy water, wiped with paint thinner before applying about 5 coats of restore black. Thank looked excellent until it started flaking off.
Uh...no I don't think so. Perhaps an early resto when gas spilled over the tank but I'm thinking we just went back over it.
Krylon Fussion Satin Black get my vote.
No surface prep need.
- Danzig
- Real Name: Paul File
Paint thinner, xylene, mr. Clean magic erasers
Brake Fluid
Grumpy
Grumpy
I agree, except I prep more. Scotch brite to remove oxidation, then clean with soap/water and then alcohol to clean the surfaceJDT wrote:Krylon Fussion Satin Black get my vote.
Adam Epp
Winnipeg, MB, Canada
74 400 (2 - sold)
74 400 (2 - sold)
Well yes, soap and water with a stiff bristle nylon brush.
Rinse, dry and paint. Works fantastic.
- GreenGenes
- Real Name: Terry
Thanks everyone for the replies... I will have some time this weekend to do some experimenting
1973 JDX-8
1974 JD300
1981 Liquifire
1981 Jag F/A 340
1974 JD300
1981 Liquifire
1981 Jag F/A 340
