Guys
The X8 project is in need of the heat deflector / firewall . Good used is fine as long as it is unmodified, cut, bent, etc. Part numbers : AM53025 and AM53026. Must be off a '73-75 reed inducted sled.
thanks
Heat Deflector WTB
Heat Deflector WTB
- Real Name: Greg Cyrocki
Re: Heat Deflector WTB
So this one off of a 73 500 wouldn't work??
-Greg
'86 Kitty cat
'77 Cyclone SOLD
'83 Sprintfire (wife's sled )
'84 Snowfire
'88 Yamaha Sno Scoot
'71 Massey Ski Whiz Special
'86 Kitty cat
'77 Cyclone SOLD
'84 Snowfire
No, the piston ported engines have the carb mounted higher, and the opening in the deflector matches that.
There were three slightly different deflectors: one for the Kohler powered sleds, one for the piston ported, and one for the reed inducted Kioritz engines.
Gotcha!! You learn something new every day.
-Greg
'86 Kitty cat
'77 Cyclone SOLD
'84 Snowfire
'86 Kitty cat
'77 Cyclone SOLD
'84 Snowfire
- VintageCatMan
- Real Name: Nick Freatman
I have a 74 jdx8 parts sled and a 75 jd 800 parts sled out here.
- Real Name: Howard Olson
How about this one? This is from a 74 or 75 JDX. It has a place for the coils and CDI.
DL Deere
Detroit Lakes, MN
73 JD 400, 500, JDX4, JDX8
74 JDX4 Special, JDX8
74 JD 295/S
75 800
76 Liquidator
77 Liquifire
78 Liquifire
80 Liquifire
80 Spitfire
83 Snowfire
Detroit Lakes, MN
74 JD 295/S
75 800
76 Liquidator
77 Liquifire
78 Liquifire
80 Liquifire
80 Spitfire
83 Snowfire
A quick look on JDParts.com indicates there were a couple more versions than I thought.
295/S and the one pictured above, which appears to be for a late 400 ( with CDI obviously ).
As well as '75 JDX8/800.400brian wrote:A quick look on JDParts.com indicates there were a couple more versions than I thought.
