77 Liquifire temp gauge
S_Kyle
Real Name: Scott Kyle
Post by S_Kyle »
I need a temp gauge for my 440 LF, it is my understanding that a generic one from napa will work. Does anyone have some kind of number or description that I can give them to get one. The original is long gone and the replacement quit last winter, the sled is several hours away right now and would like to have a temp gauge to install after my first scare this winter.
Any help will be appreciated
Scott
Scott,
The mounting hole is around 2 inches in diameter. Ask for a gauge that starts around 100 degrees F or lower. The normal operating range is 140-160 degrees for the liquifire. I have a SunPro gauge that barely moves from 100. The sensing bulb will probably have a flex cable of 3 ft or more, you will have to coil it up and wire-tie it together.
S_Kyle
Post by S_Kyle »
Is it a generic end or do I need a particular one to tread into the motor?
Most of them come with an adapter to match diffferent threads.
Stewart-Warner 82381-36 Water Temp 100-265?F 2-1/16" Tube Length-36"
S_Kyle
Post by S_Kyle »
Thanks matt, I wish I still had the orginal to fix but, it is a rider.
moontreenrg
Post by moontreenrg »
i've got a stewart warner 82326-48 from napa for $85. works great
