I need a temp gauge for my 440 LF, it is my understanding that a generic one from napa will work. Does anyone have some kind of number or description that I can give them to get one. The original is long gone and the replacement quit last winter, the sled is several hours away right now and would like to have a temp gauge to install after my first scare this winter.
Any help will be appreciated
Scott
77 Liquifire temp gauge
Scott Kyle,
Massey Whirlwind: 76 440 (2)
Mercury Hurricane 644: 72,73
OMC Snowcruiser: 66,68,70
Rupp: 70 34 Sprint
OTC Deere sled dyno
Rupp: 70 34 Sprint
OTC Deere sled dyno
Scott,
The mounting hole is around 2 inches in diameter. Ask for a gauge that starts around 100 degrees F or lower. The normal operating range is 140-160 degrees for the liquifire. I have a SunPro gauge that barely moves from 100. The sensing bulb will probably have a flex cable of 3 ft or more, you will have to coil it up and wire-tie it together.
Is it a generic end or do I need a particular one to tread into the motor?
Scott Kyle,
Rupp: 70 34 Sprint
OTC Deere sled dyno
Rupp: 70 34 Sprint
OTC Deere sled dyno
Most of them come with an adapter to match diffferent threads.
Stewart-Warner 82381-36 Water Temp 100-265?F 2-1/16" Tube Length-36"
Thanks matt, I wish I still had the orginal to fix but, it is a rider.
Scott Kyle,
Rupp: 70 34 Sprint
OTC Deere sled dyno
Rupp: 70 34 Sprint
OTC Deere sled dyno
i've got a stewart warner 82326-48 from napa for $85. works great
