sportfire
smitfire
Real Name: Dustin Smit
sportfire
Post by smitfire »
thats right.... after installing a shut off value and a few hose clamps she starts in 3 pulls,
smitfire
sportfire
Post by smitfire »
JDT still wondering on that check value,
i am having trouble again,
i flip the choke on it fires and quickly dies, then it wont start with the choke on, the gas line is full of gas
pull about ten more times with no choke and it starts
sportfire
What is it you are wondering about on the check valve?
smitfire
sportfire
Post by smitfire »
the temp is for above 33
sportfire
I think they are refering to using them with water. Which as you know would be a problem below 32.
smitfire
sportfire
Post by smitfire »
ok, so i still wonder if that is what i need or if its in my choke because today i didnt use the choke (cold engine) and in 1 pull it was running and stayed running, that is after sitting a day
a few days before i would flip the choke on and it would fire on the first pull but then i had to take the choke off and then give it ten pulls
any ideas?
sportfire
Smit how far are you from Alvord?
smitfire
sportfire
Post by smitfire »
20-30 minutes
smitfire
sportfire
Post by smitfire »
what is in alvord?
sportfire
I have some parts to pickup down there and I would be willing to stop in and have a looksee at your sled.
sportfire
Sounds to me like it's being over-fueled. You are flooding it with the enrichener.
smitfire
sportfire
Post by smitfire »
so i lowered the choke plunger and it started in two pulls inside
let it outside for a couple of hours and i did regular choke for 2 pulls and then full choke for 2 pulls and then it started
normally you dont have to do you? full choke is for very cold temps
smitfire
sportfire
Post by smitfire »
so i had it sitting for 2 weeks, had the fuel shut off and it still seemed to flood, needed 20 pulls
Rodimus Prime
sportfire
Post by Rodimus Prime »
full choke on first pull till it spit then regular choke inside or outside.
btw you probably need to fix your fuel pump.
Round slide miks have enough fuel in bowl to start and run an engine for about 30 secs to a min. if you dont have fuel in carb too do that, its usually because you didnt criss cross the vent lines on carb over the top.
smitfire
sportfire
Post by smitfire »
so then it should start if the fuel pump is weak cause there is enough gas in the bowl?
