Before I dive in......
Danzig
Real Name: Paul File
Post by Danzig »
The old stator bolt that was stripped out was extracted, points then set to .014 and the timing set to .023 before TDC. She runs, ok. I guess. She still needs choked whether hot or cold?? 2 new B9ES plugs also were installed. Gotta get some snow now and see what I have. Thanks guys!! I hope someone learned from this endeavor besides me!! I am still not sold on this yet.........but let it snow and we shall see.
Danzig
Post by Danzig »
I forgot to add...........I need a beer!!
Danzig
Post by Danzig »
I set the points first, both sets. They both read .014 wide open.
I thought you had the engine running without all the choke useage once?
1-2" of snow here last night. Too early to suit me! :angry:
Danzig
Post by Danzig »
TakeItToTheLimit wrote: Paul...I think something is misunderstood...to simplify:
1. Adjust the points for both #1 & #2
2. Set stator to correct timing of #1 cylinder (dial indicator in #1 head)
3. Reset points on #2 to correct timing (dial indicator in #2 head)
-RICH
I did it exactly as you have it listed Rich.
Danzig
Post by Danzig »
400brian wrote: I thought you had the engine running without all the choke useage once?
The no choke was required with the low idle mix backed out 5 turns. I have the carb now as close to the manual as it can get.
The choke is pulled out, pull the rope, engines starts and runs as if its loaded up, then I quickly push the choke in and she runs. This is on a hot or cold startup up.
Danzig
Post by Danzig »
Well today the X8 is sporting some new blitz black throughout!! Rich.....TITTL...... I had to go with the gloss black on the skis...........sorry.
:D
The sled looks awesome.
