I have a '74 300 that I'm still trying to get going.. I had the cylinders popping off on its own with a mikuni conversion last week, but won't keep going. I've advanced the fly-weight on the flywheel cam when setting the gaps, but still can't get it and it's just becoming a headache now. Was wondering if anyone has ever tried, attempted, successfully put a Kohler 340 2-cylinder CDI system from a spitfire onto a 295 2ax??? That's my next idea for this project.
Let me know!
Kohler 295 2ax w/ CDI?
- 69camaro
- Real Name: Duane Gjerseth
Re: Kohler 295 2ax w/ CDI?
Rylie, I really hope someone can pipe in on this. I wish I had a answer for you.
75-340/s
76-340 Liquifire
77-440 Liquifire Custom
78-440 Liquifire
84-Liquifire
84-Sportfire
84-Sprintfire
84-Snowfire
78-Polaris TXL
82-Indy 500
91-XC 400
91-Indy 500 Special
94-Indy 440 Special
95-XCR 440 Special
96-XCR 440 Special
99-XC 600
04-XC 700
81-Kawasaki 440 Invader
76-340 Liquifire
78-440 Liquifire
84-Liquifire
84-Sportfire
84-Sprintfire
84-Snowfire
78-Polaris TXL
82-Indy 500
91-XC 400
91-Indy 500 Special
94-Indy 440 Special
95-XCR 440 Special
96-XCR 440 Special
99-XC 600
04-XC 700
- HoosierDeereMan
- Real Name: Troy Miley
Are you asking if a cdi box will work with a points flywheel?
- snopro_deere
Im thinking you wanna do a complete conversion correct.. points can be a pain sometimes but you should be able to get it running. just checking its got an inline fuel pump on it right
Fear The Deere
HoosierDeereMan wrote:Are you asking if a cdi box will work with a points flywheel?
He means the whole thing - stator, CDI, coils, but I don't know if they work or not. I believe it's a completely different engine, so I doubt it.
Waterboy7
- Real Name: Rylie Sobotta
What I was thinking of doing is take the flywheel, and points & condenser plate off and install a stator, CDI and flywheel from a spitfire Kohler 340. I've never heard of this done so I thought I'd ask.
Thanks guys!
Thanks guys!
Waterboy7,
I have never tried this, but the crankshaft is the same from the K295-2AX to the Kohler powered Spitfire, so the flywheel should fit. I do not know if the stator will bolt into the cases, but I assume if your were determined enought it could be machined to match the Spitfire cases, if they are different.
Good luck, and please share your results if it works.
Waterboy7
I will keep everyone updated! Thanks for the information guys.
-Rylie
-Rylie
Waterboy7
We'll guys I had a guy, about an hour away from me, replace the condensers and point and then he timed them too... I put a mikuni on it and had it running about two weeks ago!
I still want to try the CDI idea in the future though! Now that I have acquired a couple more Kohler 295 2ax's, and have a better knowledge with the engines since my first project, I'm going to experiment with the CDI idea. So PM me if anybody has an old spitfire (w/ a Kohler 340) laying around
Thanks- Rylie
Thanks- Rylie
