I need to split the case on this engine, but am unsure what is used to reseal the halves after new crank seals are installed. Any help is greatly appreciated!
Sent from my SM-G930V using Tapatalk
Correct.....no gaskets just sealant on the machined surfaces of the case halfs.
94' Polaris indy classic touring500(girlfriend loves this 2 seater). Running
83' JD Snowfire 53rd one off assembly line (barn find in newton,iowa) currently under restoration.
1979 Kawasaki invader(has had a 440 put in but have original 340 motor-needs restored).
1980 Kawasaki 340 Invader (original,needs restored)
HAD- 1969 Chaparrel firebird SS first snowmobile when I was 12. Sold it(idiotic)
1979 JD Spitfire 340. Kick myself for selling this awesome sled
I don't coat the seals with sealant, but I do make sure where the seals sit in the case halves so very clean. I usually use a red scotchbright pad to shine things up and I make sure the grooves for the seal rib is clean and smooth.
nick80lf wrote: ↑Fri Dec 13, 2019 12:55 am
Thanks Nick!
