TB340A Kawasaki out of 80 Spit; splitting the case
snowkat79
Post by snowkat79 »
I need to split the case on this engine, but am unsure what is used to reseal the halves after new crank seals are installed. Any help is greatly appreciated!Image
Sent from my SM-G930V using Tapatalk
Re: TB340A Kawasaki out of 80 Spit; splitting the case
Yamabond 4
I second that motion.
snowkat79
Post by snowkat79 »
Yamabond huh? Im not a big Yamafan, but if this is the most recommended method....its hard to argue against results!
I sell and use the Threebond version, no issues on my engines.
https://www.newbreedparts.com/newbreed/ ... asket.html
I have used both successfully, so it's buyer's choice.
snowkat79
Post by snowkat79 »
But there's no gaskets, just this liquid gasket stuff right?
Correct.....no gaskets just sealant on the machined surfaces of the case halfs.
snowkat79
Post by snowkat79 »
nick80lf wrote:Correct.....no gaskets just sealant on the machined surfaces of the case halfs.
Awesome, thanks!
JAH76
Real Name: Jason Hanna
Post by JAH76 »
Yamabond 4 for sure
94' Polaris indy classic touring500(girlfriend loves this 2 seater). Running
83' JD Snowfire 53rd one off assembly line (barn find in newton,iowa) currently under restoration.
1979 Kawasaki invader(has had a 440 put in but have original 340 motor-needs restored).
1980 Kawasaki 340 Invader (original,needs restored)
HAD- 1969 Chaparrel firebird SS first snowmobile when I was 12. Sold it(idiotic)
1979 JD Spitfire 340. Kick myself for selling this awesome sled
snowkat79
Post by snowkat79 »
nick80lf wrote: ↑Sun Feb 03, 2019 5:06 pm Correct.....no gaskets just sealant on the machined surfaces of the case halfs.
So no sealant on the seals themselves, just on the crankcase halves?
I don't coat the seals with sealant, but I do make sure where the seals sit in the case halves so very clean. I usually use a red scotchbright pad to shine things up and I make sure the grooves for the seal rib is clean and smooth.
snowkat79
Post by snowkat79 »
nick80lf wrote: ↑Fri Dec 13, 2019 12:55 am I don't coat the seals with sealant, but I do make sure where the seals sit in the case halves so very clean. I usually use a red scotchbright pad to shine things up and I make sure the grooves for the seal rib is clean and smooth.
Thanks Nick!
